Old 02-09-2018, 06:19 PM   #4
78F350
Motorist & Coffee Drinker
78F350's Avatar
I just had an '04 instrument cluster apart. The levers contact micro switches internally. Small, but replaceable if you can solder. ...if that is in fact the problem.
Disassembly was fairly straightforward; small screws and gentle prying.
Here's the guide to remove the cluster: https://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/90-ELEC-996_Cluster.htm
Be very careful removing the connectors on the back. They are likely to be brittle. I look in through the windshield to connect/disconnect them.
