Old 02-09-2018, 02:18 PM   #11
titaniumdave
Originally Posted by specboxCO View Post
I used an electric PS pump from a mid 2000s Volvo s40. Cost me $20 from a junk yard and works great. Way easier to find than an MR2 pump. Hardest part was making the fittings for the rack. Had to silver solder AN fittings to the existing brass connectors.
The tensioner was from a 2004 v8 Touareg. Same engine, just slightly different layout with a shorter tensioner for better clearance. You may not need it, as I was trying to get away from needing the upper idler, but it put the tensioner on the wrong side of the belt that way and the clearance was really tight.
Thanks for the Volvo tip! Lines are easy, I build bicycle frame for a living so been soldering bits together for over 40 years I will look for that tensioner...
titaniumdave is offline   Reply With Quote
