The cradle looks like it will sit very low. Mine is a similar concept, but sits much higher up, so the bottom of the cradle is level with the bottom of the sump. I am still a little worried about clearance (albeit a track car rather than a street car) and am fabricating a skid plate for it.
For your belt run, what accessories are you planning on using? I ended up using a tensioner from a touareg and cutting down the idler from the fan drive to make mine work with just an alternator.
