Originally Posted by wjswireless
I have an 03 boxster and I haven't seen the resolution written about so far.
I have to turn the key and hold it in the far position. I hear slight click and if I leave it turned for sometimes 1min sometimes 40 mins it will always start right up. No clue what else to check.
So far my battery is 100% alternator 100% I checked fuses by the clutch and also pulled the relays to check for corrosion. I did the same in the trunk. I replaced the electronic ignition switch and here we are... Still have to sit there and wait forever to get it started...
Any help would be greatly appreciated.
That's weird, by design if you turn the key to on position and leave it there without starting the car, after a minute or two it will no longer start the car unless you turn it off then back on. It may be your transponder not sensing the frequency from the key?
