Help...Replaced Electronic Ignition same problem...
I have an 03 boxster and I haven't seen the resolution written about so far.
I have to turn the key and hold it in the far position. I hear slight click and if I leave it turned for sometimes 1min sometimes 40 mins it will always start right up. No clue what else to check.
So far my battery is 100% alternator 100% I checked fuses by the clutch and also pulled the relays to check for corrosion. I did the same in the trunk. I replaced the electronic ignition switch and here we are... Still have to sit there and wait forever to get it started...
Any help would be greatly appreciated.
