My 01S just had a horn problem. Horn worked with key out of ignition and stopped working when the key was in. Turned out there was a broken horn ground wire in the steering wheel. Once the wire was repaired, the horn works normally. Did you adjust the telescoping of steering wheel when replacing the ignition switch? My guess is this action led to my wire breaking.
