Old 02-03-2018, 01:25 PM   #2
JFP in PA
P0011 indicates that your can deviation values on bank #1 and crank position sensor are outside nominal values (+/-10 degrees), what are your actual cam deviation value readings?
P0011 Position of Camshaft in Relation to Crankshaft, Bank 1 – Below Limit
Diagnosis conditions
• Idle speed
• Reference mark recognized
• Engine speed between 600 rpm and 1200 rpm.
• Engine temperature greater than 40 °C
• No fault in camshaft position sensors
• Reference mark OK
• No fault in camshaft adjustment
• No fault in engine temperature
• No fault in camshaft adjustment output stage
Possible fault cause
◆ Allocation of camshaft to inlet camshaft incorrect
Diagnosis/Troubleshooting
Note!
• This fault is stored if the engine was disassembled and the allocation of the camshaft to the inlet camshaft was incorrectly set.
