Old 01-31-2018, 10:49 AM   #11
Vidyashankara
Originally Posted by Boxstard View Post
I fixed my SAI last winter, not knowning cheaper MB parts... That changeover valve should work, only the difference is the 90-deg orientation of small nipple but you will be fine with enough length silicone hose.
Did you check if the vacuum reservoir is holding vacuum and the solenoid switch is functioning to apply vacuum to the changeover valve?
This winter I noticed that my SAI motor was running erratically and got CEL... but it was just a fuse on its last leg... New fuse was all it took.
Good luck!
Hey! I havent diagnosed any of the parts as yet. Just that I get P0410 and P1411. Once the weather gets warmer, I will start pulling things around and seeing what needs to be replaced. The pump starts up and turns off after a couple of mins, so that should be good.
Vidyashankara is offline   Reply With Quote
