Old 01-30-2018, 12:03 PM   #7
speedyspaghetti
Problem is the joint of number 3.
I cleaned and regreased the ball joints with grease for drive shafts / cv joints. It's a very tough grease. Works without problems. Also did this on the rear ones. It's a bit tricky to remove and install the circlips that hold the rubber bellows that protect the joints.
if the ball joint is gone, you need new 996 341 043 06 (after market parts are also available). The ball joint can't be replaced.
Regards, Markus
Markus - this is awesome. I found the EPS version on FCP Euro for $130 - is this a reliable aftermarket brand or should I go with an OEM for about $175? Is it possible that both the rear and fronts need to be replaced or would the steering wheel vibration more likely be caused by the front?
speedyspaghetti is offline   Reply With Quote
