Number 1427. Manual 118k (bought in 2013 at 105k)
- Koni FSD and H&R M030 spec springs
- Rear adjustable toe links with uprated Fluoro rod ends
- Rear lower alu brace bar
- Powerflex Black ARB bushes
- Drilled top mount turrets
- Ferodo DS2500 brake pads, ATE Blue fluid, standard discs and rear pads
- HEL braided lines
- Stainless manifolds (no cats I'm in the UK!)
- 100 cell cats
- Carnewal modified exhaust
- 4" under drive pulley
- Metal needle roller bearings fitted to OE shortshifter
- Customised geometry
- DIY behind the grille black metal mesh
- Alu pedal set (helps me for heel and toe)
- CREE LED front sidelights
- LED rear number plate lights
- Wahler low temp thermostat
- Lots of preventative maintenance
- Well travelled in Europe and UK.
