Old 01-30-2018, 04:10 AM   #11
edc
550 Anniversary
edc's Avatar
Number 1427. Manual 118k (bought in 2013 at 105k)
- Koni FSD and H&R M030 spec springs
- Rear adjustable toe links with uprated Fluoro rod ends
- Rear lower alu brace bar
- Powerflex Black ARB bushes
- Drilled top mount turrets
- Ferodo DS2500 brake pads, ATE Blue fluid, standard discs and rear pads
- HEL braided lines
- Stainless manifolds (no cats I'm in the UK!)
- 100 cell cats
- Carnewal modified exhaust
- 4" under drive pulley
- Metal needle roller bearings fitted to OE shortshifter
- Customised geometry
- DIY behind the grille black metal mesh
- Alu pedal set (helps me for heel and toe)
- CREE LED front sidelights
- LED rear number plate lights
- Wahler low temp thermostat
- Lots of preventative maintenance
- Well travelled in Europe and UK.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
