Old 01-29-2018, 07:45 PM   #6
Smallblock454
Originally Posted by speedyspaghetti View Post
It feels like a rapid clunk/judder at all speeds above 20 mph.
Problem is the joint of number 3.
I cleaned and regreased the ball joints with grease for drive shafts / cv joints. It's a very tough grease. Works without problems. Also did this on the rear ones. It's a bit tricky to remove and install the circlips that hold the rubber bellows that protect the joints.
if the ball joint is gone, you need new 996 341 043 06 (after market parts are also available). The ball joint can't be replaced.
Regards, Markus
Smallblock454 is online now   Reply With Quote
