Were you able to see data from the O2 sensors via OBDII?
Pretty certain i could watch the cycling of the O2 sensors on my LS1 car via OBD2 data software, if one of the sensors isn't registering voltage changes, it's likely bad and as a result adjusting fuel towards that bank...which can obviously cause a lean or rich condition depending on the failure mode.
