Old 01-26-2018, 09:31 PM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
I'm not sure this is a good idea. Just a rich fuel mixture causes the cats to overheat and burn out.
I was thinking of flushing them out long before actually running the engine. The Jet Fuel would all be evaporated out (and blown through with compressed air when I flushed) Do you think that would still be a problem?
...And yes, if one or more header bolt shears off this is also a problem. But if you soak them in rust dessolver (min. 2-3 days and don't start the engine in this time) ...
On the first day, I sprayed them with penetrating oil, and I have done it again a few times. There is still risk, but I think I can remove them safely if needed.
The rear cats and muffler are already unbolted. I am going to replace them with a good, dry parts before I start. The 'wet' muffler from this car will become my spare.
