Old 01-25-2018, 07:47 AM   #1
Oldcarguy
Oldcarguy's Avatar
GBox 2nd gear detent installed yesterday. Took less than an hour. Tools used were 8 inch 3/8” swivel head ratchet, 3/8” 15 inch breaker bar, 8mm allen head male socket, 13mm box head wrench, and 7mm flat end (not ball head) allen wrench.
- Use of the 7mm allen wrench as the extract tool was brilliant as suggested in the post below. I did not have clearance to use either of my flex head magnets and they would not have worked as well anyway (if at all).
2nd Gear Detent Replacement,
- I did the install with the transmission in 1st gear to move the counterweight out of the way. The little L shaped heat shield cover was MIA on my car. Will add to my Sunset parts list for order.
- I think the Borla exhaust gave me the room to use the 15” breaker bar. The 8mm plug came lose with no problems.
- I lightly oiled the new detent with Mobil 1 0w-40. Even though I was very careful to align the detent, I did have to rotate it slightly to seat it correctly. I heard and felt it when it “dropped” into place
Haven’t had a chance to drive it due to weather, but it static shifts ok into all gears and reverse. Here’re a few pics:
Rgds, Fred
