Old 01-24-2018, 02:02 AM   #2
edc
550 Anniversary
edc's Avatar
Originally Posted by square-root View Post
Hmmm, won't the alu pipe, given its thermal conductivity, heat up the air as it moves between the airbox and the throttle body? Most people seem to prefer silicone tubing.
You can use whatever you want. I originally mocked mine up using plastic drainage downpipe. This was cheap, readily available and gave results. For sure if you are after the ultimate set up with no cost concern there will be other ways to get a fraction more.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
