Old 01-23-2018, 04:08 PM   #16
Porsche-Eh
Is this your "go-to" solution for CELs? I ask because this is the second time you've offered it as a "solution" in little more than a week. You should not be recommending this to others.
If you're not capable of fixing a car, you should look in to getting a regular mechanic that can.
Hahaha.... removing warning lights IS fixing it I have a Autel MaxiDiag Elite for when things really do break. Speaking of which, I'll post a new thread for you PW that if I can't fix (code 46) will result in another bulb being pulled Pretty soon, I think I will have no cluster - might as well remove that too.
OP: Wow, okay. Let's see if we can't get that sorted for you then.
Cheers.
Porsche-Eh is offline   Reply With Quote
