Old 01-22-2018, 03:26 PM   #16
Smallblock454
At first the engine was not my priority because it had been in that condition for four months. As soon as I drained the water and oil, the condition changed and the internal engine was exposed to air. Then it became urgent.
Well, problem here is if the valves of a cylinder are open, the cylinder is exposed to air.
I think that is also why you have water in one cylinder, but not in all. If the water was really clean, the damage might be not that bad.
Primary problem in that case are the piston rings.
If the water wasn't clean, than we have a bigger problem, because all the debree is in the engine and that will cause major problems. So our major problem is not only to get all water / huminity out of the engine but also all debree.
In general i would say it's safer to rebuilt the engine; or at least pull the heads and oil pan etc. and clean everything up, just to make shure possible debree doesn't eat up the engine. As you know most M96 parts are made of alloy, not steel.
Hope weather conditions get better soon. But if you can work in a t-shirt it might be not that bad. Over here in Germany we have snow and below 40 degrees F. So no t-shirt weather.
Regards, Markus
