					Originally Posted by Hinemn  Funny you should mention the wrist pins, I felt pretty confident up until I saw the YouTube video of them being installed, looks very challenging but doable with either the proper tool or a fabricated one. How do you know if the piston and connecting rod are lined up before inserting the wrist pin?
Pre position the connecting rod, as I recall that is BDC.  Then line up the piston compress the rings and install it in the bore.  I had everything  slopped in Mobil1.  Gently tap the piston towards the rod while watching through the pin / clip installation hole.  When it got close I cheated to get the final alignment by moving the crankshaft slightly.  I also made my own wrist pin / clip  installation tool with 3/4 electrical conduit and socket extensions.
The hardest part was getting the wrist pin clips into the installation tool without over bending them.  I ended up using a piece of wood and a screwdriver.  It was not graceful.  The glenn986 video shows the tool he made to do this which was graceful.
