Old 01-21-2018, 10:47 PM   #15
78F350
Motorist & Coffee Drinker
78F350's Avatar
Markus. I agree with what you posted, but want to clarify a few things.
...it's important to get the water out there a.s.a.p. Much more important than seats and other stuff.
At first the engine was not my priority because it had been in that condition for four months. As soon as I drained the water and oil, the condition changed and the internal engine was exposed to air. Then it became urgent.
...Maybe its a good idea to pull the oil pan before putting in new oil.
I would have pulled the oil pan, except that when I drained the engine, only two things came out: Clean water and clean oil. I think that there is minimal residual water in there now and I will flush more oil through, to clear it.
Seats: don't put them in bags. They need to dry completely. Best would be a warm, ventilated area without sun. Else you get must / mildew in the foam.
I have removed them from the bags. The purpose of the bags was to allow a mildew killing agent to seep into the seats without dispersing.
Check the ball joints and steering system for water.
Yes, soon.
...Problem with filling the cylinders with oil / 2 stroke oil ist that it's a flat engine.
Correct, they can not be filled. What I did do was spray 'fogging oil' into the spark plug holes until it flowed back out, then pumped some 2-stroke oil into both sides of the plenum.
vielen Dank
