Thanks for the info, i called the Mechanic and told him and he said Oh ok, well coin monday and ill do that for you...
Originally Posted by Tool Pants
No clue what a dash cluster id number is. Has this guy ever turned on the OBD on another car?
It takes 5 minutes to turn it on with the PST2/PIWIS. You simply modify the instrument cluster coding to tell the cluster it has OBC, which then turns it on. The PST2/PIWIS simply tells the cluster it was or does not have the OBC. No id number is involved.
