Old 01-17-2018, 04:59 AM   #1
Quadcammer
It's not plug & play to connect a 5.2 DME, 99 IC, 99 BCU / alarm system and a 987 MAF to a 01 3.2S engine.
They have done some eletronic and software mods for shure. That often means that you don't get an DTC because the DME/system gets fooled by intention.
What transmission do you have in the car? AT, MT6, MT5? If AT, that could also cause problems.
Regards, Markus
no no,
lets be clear.
99 everything, including the maf (not a 987 maf). Think of the motor as an upsized 2.5L with a intake manifold resonance flap.
The SIZE of the maf sampling tube has been increased, but that is adjusted with maf scaling.
Tranny is a MT 5 speed.
The car runs perfectly fine for 30 minutes, and runs perfectly fine up to 6000rpm after 30 minutes, and then runs fine after shutting it off for another 30 min.
If the car didn't run, or ran crappy from minute one, Id think a lot of points are valid.
Will review that document porsche-eh.
Thanks everyone for your comments.
