Old 08-25-2006, 01:38 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
So, say i were to just have porsche activate the OBC...but not install the switch, Would the OBC display the outside air temp by default...i just wouldnt be able to scroll through other modes???? Would this be correct?
Originally Posted by RandallNeighbour
I have a 97 as well and it depends on if your car was an early production model or a late production model. Mine was one of the first off the assembly line and there is no temp sensor in the front bumper. One must have a temp sensor to get the reading.
You can turn this feature on by asking your dealer to enable the OBC (On Board Computer). if you hook a switch up to your dash, you can also get other things on that part of the display such as miles per gallon, miles until empty, etc.
http://www.whiteson.org/boxster/mods/obc/
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
