Old 01-16-2018, 05:30 AM   #1178
itsnotanova
I have one but I need it for myself in case a car comes in without the key. It makes life easier having the key but you can remove them without a key using a 6 sided socket. I think you use a 24mm. It's been awhile since I've had to use a socket so that size might be off. The socket should be just a tad too small to fit over the bolt head. Hammer the socket onto the lug bolt and it should hold enough to remove the lug bolt. Before you completely get the bolt out, remove the socket by tapping at it from a few different angles. Once you have it off then you can chuck those "security bolts" as far as you can throw them. They're kind of pointless because they won't slow down a real wheel thief. I sell 4 clean rust free lug bolts for $20 shipped and $2.50 for any additional bolt.
Woody
