Old 01-15-2018, 09:44 PM   #5
boxfix
I had a similar vacuum leak and SAI that would not reset.
Trying to get the 986 smogged in CA.
I had multiple vacuum leaks.
My vacuum reservoir was leaking. I put a vacuum hand pump and gauge on it with the reservoir in place and used long needle nose pliers to get the hose off and connect a test hose directly to the canister. It would not hold vacuum, but the replacement reservoir would hold vacuum.
New reservoir was like $22.
[you have to take the alternator out to reach the reservoir for R&R. I just put the second reservoir in the corner of the engine compartment and left the old one in ther unhooked from the vacuum system.]
I also had the at "L" not in the hole in the rubber part. I used a brass barbed fitting in the rubber manifold and high temp silicon tubing to connect the check valve.
I replace every bit of rubber hose I could with 3mm silicon hose.
I then inserted a vacuum gauge in the system with a "T" fitting. The manual says you should get from 12 to 19 inches of vacuum at idle. I had about 17.
Then all the "MONITORS" went away. If you have a Durametric you can see if the monitor pass or fail.
Be happy to answer any questions or PM me.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
