Thread: Milky coolant.
Old 01-14-2018, 07:11 AM   #1
JFP in PA
Originally Posted by rexcramer View Post
Pull the oil filter and see what is inside of that. If it's clean, you can reinstall the filter and just top off with oil. Zero first hand experience, I believe the o-rings on the oil cooler can fail and allow cross contamination of coolant and oil. Best of luck.
O-ring failures on the oil cooler lead to external leaks, internal failure of the cooler leads to intermix.
