Old 01-14-2018, 02:44 AM   #10
Troutman
It seems that you may have enough material to use a pair of vicegrips, but after soaking the studs for a couple of days with PBB and if you still get a stubborn stud, before risking snapping the remaining part off, you may want to use a butane small torch on the stud prior of the vicegrips.
Good luck!
No chance of vice grips working. These are very well seized in.
Troutman is offline   Reply With Quote
