Old 01-12-2018, 07:29 AM   #2
speedyspaghetti
Originally Posted by jcslocum View Post
Those mechanical items listed if the are shot/loose will all contribute to the issue. The tie rod ends helped with only 1 part of the system. The next to replace are the strut mounts, and then work your way thru the full list. The rear trailing arms are also hurting the front end feel. The car looks to just have a worn out suspension and it needs a rebuild and then an alignment. As you work away at the list, things will continue to improve.
I should be able to do front and rear track arms without re-doing the alignment, right?
speedyspaghetti is offline   Reply With Quote
