Old 01-11-2018, 10:39 AM   #2
911monty
911monty's Avatar
Have you checked vacuum at the oil cap. This could be caused by a failing AOS. According to Dr. Raby there are two failure modes for the AOS. It can fail in a condition that pulls oil from the oil pump pickup, sometimes accompanied by a high pitch squeal from main seal(s). Since max vacuum occurs at idle it's a possibility.
See discussion attached Looks like AOS, but engine WOES
