Before you adjust the shoe star (adjuster) the E-brake handle cable should be loosened. Then you make the adjustment at the star ex: 9 clicks until wheel does not turn then loosen about 4 clicks do both wheels then tighten the cable at the ebrake after shoe adjustments on both rear wheels
5280 Cruising @High Altitude
Seal Gray & K&N Filter
