Old 01-11-2018, 07:11 AM   #1
jcslocum
Project Addicted
jcslocum's Avatar
Those mechanical items listed if the are shot/loose will all contribute to the issue. The tie rod ends helped with only 1 part of the system. The next to replace are the strut mounts, and then work your way thru the full list. The rear trailing arms are also hurting the front end feel. The car looks to just have a worn out suspension and it needs a rebuild and then an alignment. As you work away at the list, things will continue to improve.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
