Old 01-10-2018, 12:36 PM   #5
AZ986S
AZ986S's Avatar
I think that after the live event, all the data is archived there and you can go back and view your laps, compare them, etc...
The only thing I haven't figured out is that graphic that shows several gauges and stuff - for me it has always been a static image - maybe when viewing a live stream it shows some activity?
Yes I have the RaceCapture/Track and I have been liking it so far. A friend lent me a Solo DL so I am going to use that this weekend, and also I will be reviewing the Apex Pro device so it should be a busy weekend, I may not get a chance to run the RaceCapture until Sunday afternoon after I turn in the Apex Pro.
Wow! Apex Pro looks pretty cool! Might have to test that some day...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
