Old 01-10-2018, 07:31 AM   #2
JFP in PA
Originally Posted by Brian in Tucson View Post
How many miles on the engine? Oil pumps almost never wear out. Bearings do and there are a whole lot of bearings in these engines. And past experience on other engines has taught me that low oil pressure at idle indicates a worn engine.
Sorry. I think you need a replacement. Or just live with the low oil pressure for a while--it could last for years.
Can't agree. These engine's are known for weak or weakening oil pump oil pressure relief valve springs, Porsche even released an update kit with a spring and updated piston to address the problem, retail cost around $20 and 5 min. DIY to change.
Before thinking about replacement engines, I would:
1. First check the actual oil pressure with a known gauge, you wouldn't be the first with a bad sender.
2. Get the updated parts and install them.
