Old 01-10-2018, 07:46 AM   #13
DaveBBOXSTER
Taken car out and the only thing now wrong is that the heated mirrors stay on and when driving the switch light is bright and it won't turn off at the switch...When stopped with ignition off and key out the switch light goes dim and the heating of mirrors stops. Am now thinking it could be the switch itself that is faulty? Looked behind cover but couldn't get switch out...will need to look that up.
STILL I CANNOT ACCEPT THAT the heated mirrors can still work with the fuse removed this makes no logical sense and is there a separate module or unit that controls the heated mirrors? mine is shown as 5Amp fuse \ Row C position 7 (from left?) referred to as "Terminal X" Why is it called terminal X? Seems strange that it just has a 5Amp?
Surely, if I take the heated mirror switch out or off it must stop working...If so it must be a broken switch!?!
DaveBBOXSTER is offline   Reply With Quote
