Old 01-10-2018, 06:22 AM   #1
Brian in Tucson
Originally Posted by gabedrummin View Post
Low Oil Pressure At Idle ? Is there any way to increase idle oil pressure ?Can the gears in the oil pump be replaced. Is the only recourse to replace the motor.Oil pressure off idle is fine . Only when stopped with hot motor will oil light blink.Motor runs great.No noise.
How many miles on the engine? Oil pumps almost never wear out. Bearings do and there are a whole lot of bearings in these engines. And past experience on other engines has taught me that low oil pressure at idle indicates a worn engine.
Sorry. I think you need a replacement. Or just live with the low oil pressure for a while--it could last for years.
2001 Boxster
2007 Toyota Highlander
