Thanks johne4.
I also have the Durametric software and I will reset it when I get my connector back (left it at my Dad's place last month).
That is a handy piece of software to have. I had to reset my ABS system after a speed sensor replacement- worked like a charm.
Tool Pants- the battery was disconnected when the switch was replaced and when the airbag was removed/replaced.
The switch replacement was easier than I expected. Those 2 torx screws holding the airbag were a little tricky to remove because of how far they are recessed.
I upgraded to the 4-stalk switch and will wire the OBC stalk to the intrument cluster when I get the wire/connector that was out-of-stock.
I bought the switch from Sunset Porsche and Jeff was very helpful in ensuring that I got all the parts I needed. The switch lists for $237 and their price was $157.
Thanks for the help.
mike
