Thread: Airbag Light
Old 08-25-2006, 05:26 AM   #3
johne4
Yes, you will have to have it reset
I have read several thread that indicates if you disconnect your battery overnight it will clear it, I tried that, even had it disconnected for three days and it didn't work, also read somewhere that it will clear after 50 cycles, that hasn't work either.
Some dealers will clear it for free, most will charge you. I opted to purchase the diagnostic tool from Durametric ($247), since I attend to keep my Boxster and do all my own work.
For the record-The reason my light came on was self inflicted (bonehead move). I was replacing the window regulator, had the battery disconnected, I reconnected the battery to check the operation and adjustment of the window before I put everything back together, yep, had the airbag disconnected/removed creating the fault.
johne4 is offline   Reply With Quote
