Old 01-08-2018, 07:14 AM   #1
barkinfool
barkinfool's Avatar
Symptoms sound like it is the ignition switch & not the ECU (which would be much more costly). Take your time & you'll be able to change the switch - it is definitely a common failure & something anybody can fix! Good luck & let us know if that solves the problem.
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
