Old 01-07-2018, 07:40 AM   #1
key_lime
key_lime's Avatar
Thank you everyone for these suggestions
Thing with fill tube, only if you were adding oil would that come into play
My oil currently sits at the maximum mark shown on the digital readout – maybe this, combined with the G-forces of driving is forcing excess oil back up the tube (and out) ?
What about before last week, were you seeing oil?
I hadn’t noticed any oil leakage prior to last week, no.
When car is running how is the vacuum on the oil fill cap when you remove and does the engine run differently?
There is also no discernible change in how the engine runs with or without the oil filler cap, and very little suction at the top of the filler tube in the trunk. I guess this would make sense if I was already losing vacuum downstream? I think it’s a certainty the tube has failed at this point, just a matter of what else
Here's a few pics from the gallery of leaks I've fixed on some of my 986s:
These are very helpful photos, thanks. I agree with you (and everyone else) with respect to cleaning the underside up before trying to fault find any further. I have a new AOS and middle filler tube on order, and will give the underbody a deep clean once I’ve got them fitted
Originally Posted by Geof3 View Post
If you do your spark plug tubes be careful you don’t break one…. you do need a tool, no matter what
I have one of these arriving tomorrow after seeing it used in a spark plug tube removal video on youtube. Hopefully it does the trick…
key_lime is offline   Reply With Quote
