Old 01-06-2018, 05:47 PM   #4
Gilles
Wink
The car has cooled a bit now. Oil is at the third bar. And halfway on the dipstick. Replaced the aos in 2014 with about 92k miles on the car. Now at 103 so aos should be fine I’d assume?
Hello Jake, you may want to get a manometer to check the vacuum, I believe this will tell you the health of the AOS...
Also thanks to BYprodriver.. now I do let the engine idle for 30-45 sec before shooting it down to allow the oil from the heads go back to the sump, allowing you a more accurate level reading.
Regarding the weather.. right now is really cold, like 59-60
Gilles is offline   Reply With Quote
