Old 01-06-2018, 01:02 PM   #5
MN 986
MN 986's Avatar
One of my favorite mods was putting o 204 top/frame on my 2002 (it's cold up here in MN and I like to drive top down as often as possible early Spring to late Fall).
I used the instructions linked above and did not remove the clamshell. It was much easier than expected. The tip to leave the bolts loose at first is a good one. Even though I had marked the frame location, the 2004 top fit slightly differently and needed to be adjusted so the latch would not contact the plastic windscreen. Good luck and enjoy!
MN 986 is offline   Reply With Quote
