Agree clean to determine origin
Thing with fill tube, only if you were adding oil would that come into play
What about before last week, were you seeing oil?
When car is running how is the vacuum on the oil fill cap when you remove and does the engine run differently?
If you have a crack in your fill tube, that would be a vacuum leak similar to removing the fill cap.
Seal Grey
