Oh man, you could have a genuine Porsche electronics nightmare on your hand. Is it possible someone tried to bypass the onboard security? Which is almost impossible. If the remotes don’t work it’s possible you have a fried immobilizer. I remember reading somewhere that the car will can go into a sleep mode, if you will, after a time. I believe it’s covered in the manual. I don’t recall the specifics. Do your keys lock and unlock the door manually? Check to see if the “little green pill” is inside the fob, or if it’s broken. The key won’t work unless the whole system can talk to each other, and the little pill in the key is the keymaster...
