Old 01-03-2018, 04:33 AM   #13
rfuerst911sc
You basically did the same thing I did on my GHL twin can muffler . But I went with Car Chemistry baffles/discs/exhaust wool . I bought one baffled tube about 14 " long and four discs that the OD would fit in the ID of my exhaust tips . Cut the 14 " tube in half , welded the discs to the tubes roughly at the ends of the tubes and then wrapped with the exhaust steel wool . Slid them in place and drilled one small hole each and used a rivet to hold them in place .
A low rumble at idle to a screaming banshee at 7K with only a hint of drone I am very happy with the results . I also like the way the exposed disc's look .
rfuerst911sc is online now   Reply With Quote
