Thanks for the info regarding the front bar. Looks like I might just try the rear cayman bar considering how cheap they are. I've noticed some are sold with endlinks and some are sold without. I know I will need the bushings and little metal brackets/clamp pieces for the cayman bar but I'm assuming the endlinks on my car right now will work just fine?
Also, I've found out that the 987 base cayman rear bar is 18.5mm. According to ECS, the 987 base boxster, boxster s, and cayman s all use the 19.3mm rear bar referenced in the chart. At least for the 987.1 non PASM cars. For anyone considering this upgrade, the part number for the 19.3mm bar is 98733370104.
