Old 01-02-2018, 06:49 AM   #10
Badboybox
Badboybox's Avatar
When cranking watch Tach. If no RPM measured, possible Crank sensor, if RPMs, possible Fuel Pump relay. Of course there are other possible causes but those are common when cranking no start.
When my Relay went, car had been driving fine, came to a stop light, it just died
When I crank it over the tech does not move.if it is the crank position sensor would that throw a code or an engine light.i have no check engine light on.did you have your crank sensor go out or your fuel pump relay? Thanks.
Badboybox is offline   Reply With Quote
