Part of the issue is brake clearance. If those offsets are listed for an S (bigger brakes) you should be fine, though the fronts might be a little close at the 50. Try them, worse case they need a little and you get what you want/need, or they are good to go and saves you some $ for the next fun toy! I personally think if you can avoid spacers, do it. The farther out of “spec” a wheels sits on the axle causes more stress on wheel bearings/axles/suspension. If you add spacers you will most likely need longer lugs as well.
