Old 12-30-2017, 11:39 AM   #13
itsnotanova
You don’t have to ride in the frunk. Having a friend help can help narrow down where the noise is by sticking your heads pout the window. That will help determine if the noise is inside or outside and either the front or back. Four ears are better than two. If you notice the noise is inside, then the you can start feeling around the top area and see if you can find what part is rattling. If you find the noise is on the outside, then you can find what wheel is making the noise. Once you know what wheel, then you can investigate that area closer.
Woody
