Old 12-30-2017, 05:53 AM   #18
joecal
joecal's Avatar
Originally Posted by 1096369fred View Post
You can replace both inside and outside micro switches......it is not to hard, once you get the door opened up..... I am fighting a "wont drop" issue without much luck so far.... I have replaced the outside handle micro switch, Done the cable tie trick, and replaced the regulator.... With a cheap one.... Which I will likely suffer for.....
Good luck!
F.
Driver outside handle micro switch:
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
I'm having the same problem as you with a "won't drop" enough issue, it drops a little but not enough as it should. The electronics in these cars have a lot to be desired.
1999 Boxster base w/sport package Ocean Blue Metallic/Savanna Beige
joecal is offline   Reply With Quote
