Old 08-24-2006, 04:27 AM   #2
RandallNeighbour
I have yet to do what you want to do, but I sure have investigated it.
Going from a 2.5 to a 3.2 is gonna be expensive... you need the engine, new ECU, wiring harness, exhaust, yada yada yada. Moreover, the 3.2 is e-gas and your 2.5 is the conventional cable throttle type, so that would have to be changed as well.
Best bet for the engine swap is to go with a 3.4. More power, you can get a salvaged or rebuilt non e-gas version, and I bet the price will actually be lower than a 3.2 swap.
The TPC SC kit is 7k, and has low boost so it apparently does not burn out engines prematurely, but putting your foot in it all the time to enjoy the newfound speed can't elongate your engine life, that's for sure!
I'm headed in the SC direction, saving my pennies right now.
